the gist of the discussion is that side "A", in this case our engineering manager, says that centerless grinding is the ONLY way to get things round and to size. side "B", our grind department personell, says this is not true. and by way of explanation they say while centerless grinding can leave things round and to size it is not the ONLY way, in fact a tendency of centerless grinding is that things are FREQUENTLY lobed. this lobing can be reduced or eliminated to a certain extent by good grinder practice and workmanship. and if you dont have good accurate centers in a part ground between centers it will be hard to make those parts round as well, and parts ground between centers MAY be tapered and/or barrel or hour glass shaped, these have to be dealt with with good practice and workmanship and these conditions with the exception of taper are less likely with centerless grinding. once again the main point of the discussion is wether or not centerless grinding is the ONLY way to get things round and to size or not and i think the responses above indicate that that is not the case.
