Honing lubricant for carbon fiber tube
Likes Likes:  0
Results 1 to 4 of 4
    Aug 2019
    AUSTRALIA
    10
    5
    Default Honing lubricant for carbon fiber tube
    Hi all
    Hi all
    I'm new around here and must say very impressed with the amount of knowledge on the forums!!! I am looking to hone some matte 3k twill carbon fibre tube with a 0.2-0.3um on the ID and was wondering what type of oil/lubricant I should use with a flexhone to minimise possible absorption and/or material swelling?
    Kind thanks
    Blair
    Oct 2016
    Florida
    385
    914
    242
    I ream 18mm tube to increase the ID. I use tap water to remove heat, contain the dust. Carbon fiber is brutal stuff and the splinters are likely to be classified like asbestos is my guess. Tooling takes quite a beating in the process.
    Your best bet if you can is to spend the extra money to have the tube made to final dimension.
    Jul 2006
    Hillsboro, New Hampshire
    10,137
    2368
    7081
    Quote Originally Posted by Pathogen View Post
    I watch Formula One races, and seeing the pit guys grinding CF panels without dust masks makes me worried for them. I don't think the dust is as bad as asbestos, but you still shouldn't be breathing it.
    Aug 2019
    AUSTRALIA
    10
    5
    Hi pathogen. I have found a supplier that will make it to my specs but being matte I want a more polished finish on the ID but still want the matte finish on the OD.
