How can I clean the splatter off tight close quarter places
Results 1 to 16 of 16
    Jun 2017
    Indiana
    103
    6
    Default How can I clean the splatter off tight close quarter places
    I am new to welding, and this is my first sculpture. Want to clean the splatter off and paint this. Not sure what is available other than sandpaper or if sandpaper would even work.
  2. Likes ptsmith liked this post
  3. #2
    Oct 2013
    The Gorge, Oregon
    173
    35
    131
    Decrease adherent splatter in first place. Choices are anti-splatter spray or much better learn to oxy-acetylene weld or tig weld and you won’t generate splatter to begin with.
  4. Likes Scottl liked this post
  5. #3
    Jun 2017
    Indiana
    103
    6
    Tig weld would be nice, I am borrowing this mig welder. I will try the spray. Thanks
  6. #4
    Nov 2014
    Florida
    4,128
    1620
    1935
    Star Trek?
    Sandpaper ain't going to cut it IMO. You are going to need a dremel with an appropriate bit/sanding drum-disk, or a little right angle air grinder with a 3" sanding disk. ANti-spatter will work, but would need to spray it on the whole thing (as the pics make it look small?) and then wipe off your weld areas.
    https://www.mscdirect.com/browse/tn/...ing+Categories
  7. #5
    Jun 2017
    Indiana
    103
    6
    Thanks. I have a dremel! I will have to buy some bits for it though.
  8. #6
    Jan 2019
    Tennessee
    553
    176
    146
    an engraving chisel, or if really tight a hand graver.
  9. #7
    Oct 2010
    Oregon
    5,206
    4583
    1895
    On something like this, for light spatter or discoloration, I use small diameter (1") twisted wire wheels with 1/4" shanks in a die grinder or Foredom grinder. When I actually need to remove a bit of metal (adherent spatter or shaping), 1" and 2" quick-change (e.g., Roloc) sanding disks and nonwoven abrasive pads. For gross shaping of weld beads that didn't turn out as desired, carbide double-cut burrs.
    Think "Dremel", but with some real authority.
  10. Likes Kyle Smith liked this post
  11. #8
    Oct 2005
    16,572
    Quote Originally Posted by MetalArtistCandy View Post
    What a disgusting waste of good tooling.
    Please go away.
  12. Likes tdmidget, moonlight machine liked this post
  13. #9
    Langley, B.C.
    1,743
    368
    1016
    A needle gun will make short work of most spatter. But I also agree with the idea of reducing the amount of
    spatter when welding. Anti-spatter spray and attention to good setup/technique will significantly reduce the
    problem...
  14. #10
    Jun 2017
    Indiana
    103
    6
    Please go away.
    I have drill chucks listed for sale for a year, no one purchased them or even made an offer, broken and old wrenches I found at auctions for $2 per box load. Hand wheels come From a box of random parts from auctions as well. All these parts are scraps that no one wants. You may not like it, but I am sure you dont have enough money to purchase every bit of old tooling that is out there!
    If it wasnt me buying this stuff, it would be the scrapers
    Also I gave my nephew a tool box full of old tools for Christmas. Cost me only $5 in random auction box loads!
    The only tools people seem to care about any more are snap on.
    I also have more drill chucks lister for sale here if you want to buy them.
  15. #11
    Aug 2005
    Tucson AZ
    6,421
    9760
    3023
    Snap on doesn't make machinist tools. You are asking near new prices. Yes people want them. There is a store here in Tucson that does a land rush business in used tools.
    S
  16. #12
    Aug 2019
    CANADA
    British Columbia
    9
    You can get anti-splatter spray from some welding supplies: might help you a bit but I would save the time/money by doing some practice welding prior to your finished unit to dial in the settings/technique prior to making the splatter (e.g. DCEN/DCEP/AC etc at the most basic levels) . Also research to ensure you are using the proper rod etc. as this might also cause splatter.
  17. #13
    Dec 2014
    Arizona
    369
    39
    63
    You need more then anti spatter, that is terrible in every aspect. I could go on, but...
  18. #14
    Sep 2010
    Oklahoma City, OK
    4,690
    806
    1936
    Plasma torch should fix it.
  19. #15
    Nov 2013
    Eastern Massachusetts, USA
    4,898
    4858
    4859
    Please go away.
    The welding needs improvement but I kind of like the concept. A lot of the iron that goes into sculpture would otherwise be melted for scrap anyway. It's no great loss.
    One man's art is another man's eyesore and vice versa. Beauty is in the eye of the beholder. How boring life would be if we were all the same.
  20. #16
    Feb 2018
    192
    41
    42
    Do what you want with your tools. They are yours after all. It's no one else's business. And even if it's new Snap-on stuff, so what? Snap-on will gladly make more.
