How to chuck up engine valve and turn down stem .010" by grinding...
trackhound
Apr 20, 2014
Grants Pass, OR
Im dealing with a set of used rare valves that can be reused IF,,,the stems are turned down slightly, maybe .010-.015" via grinding.
I get chucking up the head but how to support the tip end..?
Either drilling a centering hole or putting it in a "cupped" end I've heard.
I've got a little knowledge on this...only enough to get myself in trouble.
Any ideas on how its really done?
OR...someone whos already providing this service?
I would use a 4 jaw chuck in the headstock of a cylindrical grinder and a female "half centre" in the tailstock to allow access along the full length of the stem. Make sure there is a chamfer on the end so that as you grind the diameter, there is still contact between the stem and centre. Are these valves not available as something close as new and the head and collet groove only modified, which is loads easier. Another way would be sourcing someone who does centreless grinding, but I doubt they will do such a small batch.
For spin grinding I use a a lever made of brass with adjustable weights to change the amount of support on the end of the part
