ballen
- Sep 25, 2011
- Garbsen, Germany
I've added a swing-down ID grinding spindle on my cylindrical grinder and am slowly learning how to use it, mostly by trying things.
I would like some advice about how to mount this stone (30mm diameter) on this arbor (23mm). I want to be able to face grind with the outer rim, so a good mount would leave most of the inside space free.
The hole in the arbor has an unthreaded section 12.35mm diameter, followed by an M12 threaded section. The hole in the stone is about 13.5mm.
I can easily turn mounting hardware from steel and/or plastic, and also have blotter paper and epoxy on hand.
