TheBigLebowski
- Sep 9, 2018
I've cut a couple of fairly large (~3.25") x 3" long Punches that I will need to make sometime next month. Typically I just wire EDM punches, but in this case I will likely need to make a few Provisionals to adjust the final size as needed.
I was thinking that instead of wire EDMing them I would buy one of those small diameter mag chucks and mount them to one of my whirlies (simco microgrind or harig duo-form)
But how well do they work? is all that extra weight hanging off the end of a 5c shank too much to get consistent results?
And if they suck is there a better option to use on a manual surface grinder?
