Hi
I recently picked up a Matrix Okuma Cylindrical Grinding Machine model GU 33 x 1650. The wheel spindle has hydrodynamic bearings. if any one of you have used this model or make please advice what is the clearance/play required between the spindle & bearing. It has a Force Feed Lube system. At Pulley end the play is 1.5mm and at the wheel end it is 0.5mm. I guess it needs to be same at both ends. can anyone please throw some light on this.
thank you in advance
regards
Pali
regards
Pali
