Hi folks !
I am the recent owner of a 1961 J&S540. It is in a definitely shabby state, but from what I could check so far since the rusty turd is at home, the worst part appears to be the outside.
For reasons I will not linger on, I have no certainty about how it lived the past years, but it sure spent some time out enjoying our rainy Brittany.
Motors are good, inlet hoses are new (well, the newest part of the machine at least). Many things probably look far worse than they really are. Hydraulic cylinder rods are bent from some dude recently trying to lift the machine from under the table, well that's life. Nothing there I cannot handle.
On the upside, I discovered the spindle is indeed a plain bearing variant. Could not anticipate that from the few shots I had been sent before the (almost) gift horse showed up...hence me not looking too deep in its mouth.
I opened up the spindle box cover yesterday to discover there is no oil there to be found... The spindle moves freely though and very smoothly. A good thing the belt is reduced to strings of gunk, if you consider that running the spindle like that would be quite unwise.
From what I understand, a bad plain bearing spindle could be a showstopper for the overhaul I have in mind.
Long story short, how would any of you wise guys assess the condition of the spindle ? I am aware of the adjustment procedure that calls for 1/100 mm axial play (IIRC), but wonder how a seasoned professional would tackle this. Any hints ?
Cheers,
-Phil
Cheers,
-Phil
