Jack Mill OD Grinders
  • Thread starter otrlt
  • Start date
  • Replies 2
  • Views 1,054
Had one in the shop 30 years ago. Not a Cincinnati, but serviceable. Only problem was the pressure switch to make sure you had lube oil before starting the spindle failed.
Thanks for your input gbent,
I think I will take a chance on the Jack Mill grinder. I have always had good fortune purchasing used equipment. My last acquisition; a non working surface grinder, turned out to be a great learning experience. My guess; it is more than likely that all that this Jack Mill may need is a hydraulic system tune-up.
