L
Luke.kerbey
Guest
Hi all,
I’ve got a jakobsen 1032 automatic down surface grinder.
It has a couple problems with the cross slide when in feed. When the table is closest to the column the table gets stuck after a certain point about 50mm from end of travel. Also when the table is closest to operator side the table jumps up or the head bumps down about 0.01mm. The problem can be overcome by limiting the table travel about 2 inches at both ends. But this isn’t helpful when grinding wider parts.
Has any one done much work on these grinders that is able to shed some light?
