depmco
- Jan 19, 2004
- Portland, OR USA
I have one of these grinders and am confused (not a rare condition for me). I know several readers of this forum have J&S grinders so maybe one of you can un-confuse me.
My grinder came with one wheel adapter. I'd like to get one or two more. Since it's a wet grinder, it is about 3" OD, with a recess on the back to protect the spindle from coolant, and a recess on the front for the spindle nut also for protection from coolant. Sopko lists an adapter for J&S grinders with exactly the correct configuration except that its internal taper is 15 degrees. My grinder has a 3"/ft taper (14 degrees and change). I'm confident of this because I tried three things: a) I measured it carefully with a vernier protractor, b) setting the vernier protractor to 15 degrees gave a poor fit to the spindle, and c) a wheel hub for my Parker Majestic grinder which has a 3"/ft taper fits the taper on my J&S perfectly. Sopko makes a 3" or so wheel adapter with 3"/ft internal taper, but the recesses are too small to fit correctly on the J&S. Sopko will make me adapters for what is probably a fair price for a custom item but still a lot of money.
The grinder spindle and adapter appear to have come this way from the factory.
My questions are:
Is this grinder unusual in having 3"/ft taper but other dimensions the same as a "normal" J&S grinder?
If not, the solution to getting adapters made custom from Sopko seems silly; what have others done?
I haven't contacted either Andmar or Jones & Shipman yet. Andmar lists wheel flanges on their web site as N/A. No clue if they were available what the taper is. For that matter do you contact Jones & Shipman in England, or Hardinge?
-- Greg
My questions are:
-- Greg
