Jones & Shipman 540 Grinder Questions - Page 4
Page 4 of 4 FirstFirst ... 234
Results 61 to 71 of 71
  1. #61
    GERMANY
    2,469
    1473
    832
    Quote Originally Posted by sameworks View Post
    Can you send me in pdf format a J&S 540 manual?
    Done, check your email.
  2. #62
    Jul 2010
    Florida, USA
    27
    Hoping I can get some help finding new wheel adapters. My 540 is a 1969 model no 72248, SN 1848/166. Based on the voltage tag it was originally a UK or European model for 380/440 50Hz power I assume. The adapter on it has two adjustable balance weights and has a shroud for the spindle. The adapter that Sopko recommended, PN 00200 will only allow for about 1 thread of engagement on the spindle nut, so it's obviously too thick. So my questions are, is my spindle the UK type or the US type? Does anyone know the proper Sopko PN or perhaps the J&S PN? And while I'm at it, the spindle nut measures out to be a 1/2-16 LH nut. Is this nut available or will I be making one? Thanks.
  3. #63
    GERMANY
    2,469
    1473
    832
    Default Jones & Shipman 540 Grinder Questions
    Quote Originally Posted by Shuttle Guy View Post
    The European JS 540 machines have a 15 degree included angle. The US ones have a 3 inch per foot taper, corresponding to 14.25 degrees included angle. (I had this wrong earlier, but corrected it.) So first figure out which taper angle your machine has. (My understanding from looking at their online catalog is that Sopko can provide either one.)
    You can see some more details in this post and others in that thread: WTB: some 1 1/4" wheel hubs for Jones & Shipman 540 grinder
    If yours is a 15-degree taper machine, you can buy used 1 1/4" hubs on Ebay UK for 40-60 pounds. New ones cost 110 pounds from Jubilee:
    540 Wheel Arbor MYFORD SPARE PARTS
    Andmar also has them but does not list a price on their web site:
    ! Parts Listing : Andmar
    I ended up purchasing a box of used hubs in the UK and having them shipped to me in Germany.
    PS: I'll check the retainer nut thread on my machine tomorrow. Jubilee lists these for 15 pounds: 540 -1400-1314 Spindle L.H. Nut
  4. Likes Peter S liked this post
  5. #64
    Jul 2010
    Florida, USA
    27
    I measured the taper and the math indicates it has an included angle of 14.25 deg. Isn't that the included angle for a 3 inch per foot taper?
    I'm expecting a return call from Sopko this AM to rectify the situation.
    I'm in USA and have not ordered from any UK suppliers yet. Perhaps its time to do so.
    Thanks for the info.
    charlie
  6. #65
    GERMANY
    2,469
    1473
    832
    Yes, you're right, it's 2 arctan(1.5"/12") = 2 arctan(0.125) = 14.250032697803595 degrees.
    But it sounds as if your machine has a US taper, so you should probably look at US suppliers first.
  7. #66
    Jul 2007
    UNITED KINGDOM
    4,579
    2344
    2143
    I'd never realized that the US and rest-of-the-world grinders had a different taper. That explains why I had to turn the taper of the balancing arbor I got to make it fit the my wheel adapters (it was hardened, but a CBN insert produced a mirror finish).
  8. Likes ballen liked this post
  9. #67
    GERMANY
    2,469
    1473
    832
    Regarding the length of the taper and threaded section:
    It seems that the majority of the J&S 540 are designed for a wheel thickness of up to about 1/2" = 13mm. But there are exceptions. My 540 APR machine was delivered with special a "heavy duty" spindle (four ball bearings instead of two) and this can take wheels up to 20mm = 3/4" thick. So the "native" flanges are a bit wider than the standard ones and the part of the spindle under the flange is a bit longer than the standard ones. Nevertheless I can use the standard flanges, I just need to add a thick spacer washer under the spindle nut.
    I am not sure but I also think that recent versions of the 540 such as the 540X are also able to take thicker wheels. The wheel hubs for these machines might also differ slightly from the earlier standard.
    If a handful of us made some careful measurements and drawings of the spindle tapers and threaded sections of our machines, it would be useful to people who are shopping for flanges.
  10. #68
    Jul 2018
    UNITED KINGDOM
    Hi
    I'm looking to replace the vertical feedscrew and nut on my 540p any help,pictures advice greatly received
  11. #69
    Jul 2018
    UNITED KINGDOM
    Hi
  12. #70
    Jul 2009
    Southampton UK
    87
    12
    13
    Quote Originally Posted by johnd1963 View Post
    Hi
    You are probably being ignored because you have hijacked a thread. I would suggest that you post a new thread in the
    machine-reconditioning-scraping-and-inspection forum
  13. #71
    Mar 2019
    North Carolina
    Would love a copy of your 540 manual if you have one in pdf.
    Thx
    Just got a 540 automatic unit with side cabinet.
