I’m busy cleaning and refurbishing a grinder. It was in a ver6 sorry state when I got it. The tank was full of grinding Gupe so I’m think8ng of taking apart the pump to clean it out rather than just flushing it through with new hydraulic fluid. Here is a schematic of what I will find inside. Now, hydraulics are something relatively new to me, and I don’t know a lot about them. I haven’t so far had a need to poke my fingers into hydraulics, but I’m very very aware how dangerous a squirt of it can be if you get it wrong! So, I’m very cautious about playing with this stuff, I don’t want to have bits of me cut off due to having it inadvertently injected into me!!
So, here are my thoughts, hopefully any hydraulic experts can correct my perceptions.
There appears to be just three sealing parts, two copper gaskets and a stuffing ring. I think I can reuse everything? I dont think I will need to replace the copper gaskets as long as I carefully mark which side , way around they are and pop them back in the same way? Not sure what the stuffing ring is made from but hopefully that is just some form of fibre rope?.
There are two pipes up to the machine from the pump. It looks like there are two pressure pipes into the machine, from reading other posts I think the centre one is the high pressure port and the one above the Exhaust pipe (S) is a low pressure outlet. So firstly, any experts, does this sound about right? Can you see any issues in taking this apart and rebuilding it? Anything I should be careful about / pointers for reassembly?
