Lapmaster 15C Repair
Sub-Micron
Jan 6, 2010
California, USA
Hello All,
I recently purchased a Lapmaster 15C from a local shop. When running it makes a ticking noise which is 30 times per table rotation. The gear reducer is 30:1 so the noise is 1 per single revolution of the DC motor. I'm trying to remove the motor/gear reducer from the machine. My problem is I can't find a way to remove the Lapping plate shaft adapter. I don't see any set screw holes in the adapter that would secure the adapter to the gear reducer shaft. I have the manual, but it doesn't show how to remove the adapter. Anyone have any ideas?
Thank you,
Roger
Mine just lifts off the shaft after removing the lapping plate from it, gravity holds it on, had to jiggle it and it came right off.
Wayne
