Sub-Micron
- Jan 6, 2010
- California, USA
Hello All,
I recently purchased a Lapmaster 15C from a local shop. When running it makes a ticking noise which is 30 times per table rotation. The gear reducer is 30:1 so the noise is 1 per single revolution of the DC motor. I'm trying to remove the motor/gear reducer from the machine. My problem is I can't find a way to remove the Lapping plate shaft adapter. I don't see any set screw holes in the adapter that would secure the adapter to the gear reducer shaft. I have the manual, but it doesn't show how to remove the adapter. Anyone have any ideas?
Thank you,
Roger
Thank you,
Roger
