FRporscheman
- Jun 9, 2018
Hi, I'm a new member and I hope I chose the correct forum for this question.
I have a pair of control arms with integrated ball joints. The joints are worn out and need rebuilding, so I pieced together a kit - new bronze bushings, new ball pins.
Now that I'm finally trying to use this kit and rebuild these ball joints, I have learned that the new bushings usually come with their own ball pins which have slightly smaller diameter balls. Thus my ball pins won't fit into the bushings.
I want to retain the ball pins that I have because they are special ones with longer pins (for geometry correction). I'm wondering if there is a way to machine the bushing so the larger ball fits into it? Can it simply be lapped? And is that something I could do myself? I have access to a small lathe.
thanks
thanks
