I take a die grinder and with about 1" long sweeps grind away any step at the parting line of a belt. Some belts are pretty bad..some OK. I like no bump/step at parting line.
Good to run the motor alone to see how smooth. Good to make a check of spindle RPM..You may not know if the motor has been changed and the wheel is going to fast. Wheel speed should not exceed the wheel marking..Some pulleys are not very high quality and balanced for high speed.
Some old wheels are oil, coolant, logged and so even with dressing still run way out of balance..Run with no wheel, then with wheel can sometimes tell if wheel is bad. A new name brand wheel will run with OK balance..Balancing is good but a 7" dressed wheel will run Ok with a dress.
Way oil is best for ways and you don't use very much so good to spring for a can of proper oil.
New to grinding? Any part taller than its bottom should be blocked in at the go side (left on most grinders.) Dress a wheel and with first near contact down feed on the right, then with slow traveling the part going toward the right.. this allows contact to a high place with not catching or climbing on the part. Catch or climb will often burn or flipping the part off the magnet...once you contact the part you can gauge feed and travel..if the wheel seems to lose RPM you are feeding or traveling to fast...
likely you know to ring test every wheel and use blotters on both sides... and have a wheel guard ..and wear safety glasses.
Grinding you don't long travel dead slow, or as fast as you can crank..but go about half that for most grinding jobs...
The amount of down feed regulates the grinding with maintain spindle RPM, tightness of sparks, sound, caution to a chancy set-up, heat of the part, these mostly what to consider.
Talking about manual surface grinding use the words Long travel, cross and down because surface grinder manufacturers are confused with WYZ for grinders. With CNC grinders it can be good to draw a little map of the direction for that/each machine so a new guy to the shop is not confused.
