Looking for somebody whop can Lap LARGE parts. 21" dia.
Results 1 to 9 of 9
    Aug 2007
    Wisconsin
    2,067
    1097
    925
    Default Looking for somebody whop can Lap LARGE parts. 21" dia.
    Per the title on the thread. We have a request where a customer is looking for .750 thick x 21" dia.
    Tolerance is +/- .00004". 1 micron.
    Hardened tool steel material, mid 50 rockwell C- Scale.
    No specific finish.
    I could grind down to hold a size/flat parallel to within +/-.0001".
    If you can do this or know somebody just PM me.
    Thank you in advance.
    Mar 2005
    Kansas
    7,412
    424
    3394
    You don't specify material.
    Could a surface plate calibrating company do the job? They have the means to inspect the job when done.
  3. Likes cash liked this post
    Aug 2007
    Wisconsin
    2,067
    1097
    925
    Updated for material- thanks for bringing this up.
    Really needs to be done on a proper lapping machine. Somebody who laps can inspect to this tolerance. I have the equipment to verify.
    Mar 2011
    Geneva Illinois USA
    6,047
    2528
    2345
    How about manufacturers of large lens and mirrors.
    Tom
    GERMANY
    2,622
    1616
    913
    Spec doesn't make sense to me. The material is only 3/4" thick. It's much too floppy to stay flat unless attached to a support structure. To hold this flatness in metal, you need a ribbed supporting structure like a 2' x 2' cast iron surface plate.
  7. Likes Pete Deal liked this post
  8. #6
    Aug 2007
    Wisconsin
    2,067
    1097
    925
    Yes- for the use this is a crazy tolerance, but what our customer requests.
    The parts are supported and so they way they are used the tolerance is more for size that flat.
  9. Likes ballen liked this post
  10. #7
    Feb 2013
    Madison, WI
    955
    1094
    613
    Have you tried Ryeco in Beloit? I'm not sure if they can, but they may be able to.
  11. Likes Zahnrad Kopf, cash liked this post
  12. #8
    Jul 2006
    Hillsboro, New Hampshire
    7,232
    1700
    5003
    Quote Originally Posted by AARONT View Post
    They have a Stahli Finegrinder, which they describe as a "flat honing machine". This might be appropriate (over a double-disk grinder) for the target size/tolerance. It looks big enough, would be worth a call.
    Ryeco, Inc. - Double Disc Grinding Specialists - Grinding
  13. Likes cash liked this post
  14. #9
    Aug 2006
    greensboro,northcarolina
    2,337
    137
    546
