Looking for Thompson manual surface grinder information
Results 1 to 16 of 16
    Sep 2012
    Minnesota
    234
    52
    84
    Default Looking for Thompson manual surface grinder information
    I have bought at an auction a Thompson 6x18 surface grinder and I am looking for some information on it. (Hopefully before I pick it up in a few days) I have been searching but cannot find much on the models Thompson made. The SN starts with D and then 6 digits (D-######) I'd like to see if I can find out how to best move it and it's age. I am renting a drop deck to haul it home with as that worked great with my mill.
    Jun 2012
    Tennessee USA
    921
    613
    537
    Don't know if it applies but a simple search turned up these links. Seems to be info available.
    THOMPSON GRINDER CO.
    Thompson | store.lathes.co.uk
    Jun 2012
    Michigan
    11,754
    3999
    4186
    I have never used this source for manual downloads but you might have a look.
    Hats off to thompson for some of the best scraping ways I have seen..a great machine..I think some later thompsons had ball way tables.. such should be cleaned if one can do that with not harming the machine..good to have the manusl.
    thompson surface grinder manual Download
    Jan 2011
    BFE Nevada/San Marcos Tx
    1,486
    1632
    854
    I picked up a Thompson 6x18 last year, to move/load forks under the machine worked just fine. Its a heavy sucker, iirc about 4000 lbs, serial# on mine starts with an F, and War Production Board tag means its early 40's vintage.
    Jun 2012
    Tennessee USA
    921
    613
    537
    Quote Originally Posted by dalmatiangirl61 View Post
    Any chance you got this from a metal stamping house in San Marcos? Apologies to the OP for going OT.
    Jan 2011
    1,486
    1632
    854
    No, it came out of a shop in Las Vegas.
  7. Likes AD Design liked this post
    Jun 2012
    Tennessee USA
    921
    613
    537
    -Thus ends the fanciful speculation of my imagination. OT over, back to our regularly scheduled programming.
  9. #8
    Jan 2011
    1,486
    1632
    854
    Did you use to run one in San Marcos? I'm not sure there is a metal stamping place in town, there is aerospace mfr north of town, plastic injectors in town, and National Oilfield used to have a place on south end of town. Maybe Steller?
  10. #9
    Jan 2011
    1,486
    1632
    854
    OP, I just looked thru my manual, do not see a listed weight, I did not weigh mine, 5K forklift handled it. If you use a forklift and approach from front of machine, throw a 4x4 or 2 between machine and lift so if it decides to slide on forks it does not take out handwheels. If moving far, or on rough ground, you might want to throw a strap around it so it does not slide left or right. Left side of machine (column side)is heavier than right, that is direction it will most likely slide to.
  11. #10
    Aug 2001
    Batavia, IL USA
    2,045
    60
    67
    I have a manual for a Thompson Model F surface grinder - PM me with an email address if you want a copy.
    Mike
  12. #11
    Jun 2012
    Tennessee USA
    921
    613
    537
    -Parkview Metal Stamping, right off I-35, just south of the 123 exit. Worked there in mid to late 1990's while living in Lockhart and Bastrop. Yes, ran a couple of the Thompson grinders there. Miss the BBQ in the area.
    Apologies once again to the OP for going OT.
  13. Likes dalmatiangirl61 liked this post
  14. #12
    Sep 2012
    Minnesota
    234
    52
    84
    Thanks folks! Mike, I'll send you a PM for the manual. I have prybars and pipes ready for rolling it along to unload it. Do these have rollers on the tables or can I leave the table mounted when transporting it?
  15. #13
    Jun 2012
    Michigan
    11,754
    3999
    4186
    It should be easy to look under the long travel and see there are ,or are not scraped ways.
    if model D I think it has ball ways,
    Good to wrap it up so not to lose any fall-off parts.
    If a scraped table be sure to set travel locks or table may slide right off.
    if no lockd tie it some how.
    set the down travel to place the wheel on a piece of wood on the chuck so down travel nut is free..
  16. Likes Mr.M, AD Design, dalmatiangirl61 liked this post
  17. #14
    Sep 2012
    Minnesota
    234
    52
    84
    Quote Originally Posted by michiganbuck View Post
    And if it is ball ways it should be fully removed for transportation, correct? It seems like it won't be that difficult to do, but if it can be blocked in place I'd be all over that ��
  18. #15
    Jun 2012
    Michigan
    11,754
    3999
    4186
    Many newer machines you just lift the table and disconnect the travel strap..but the old iron machines many have a catch part that need be removed, often one at each end..so look it over good and don't break anything.
    Most guy suggest taking off a ball or roller table..new machines they do that for sure.
  19. Likes Mr.M liked this post
  20. #16
    Aug 2001
    Batavia, IL USA
    2,045
    60
    67
    I replied to your email a few minutes ago with a PDF of the manual that I have, so let me know if it doesn't show up,
    Mike
