Magnetic chuck strength?
Results 1 to 9 of 9
    Jan 2003
    Imlay City, Michigan
    1,987
    102
    209
    Default Magnetic chuck strength?
    I bought a 12" x 12" x 6" Suburban compound magnetic sine plate, weighs around 200 + lbs.?
    My question, can I use the magnet to hold a steel plate with a swivel eyebolt to be able to pick this up, and what size plate?
    What do you guy's use to move these around the shop?
    Thanks for any suggestions!
    Kevin
    May 2010
    Indiana
    225
    51
    I always just slid it onto a diecart that had a plexiglass sheet on it to move it.
  3. Likes michiganbuck liked this post
    Jan 2003
    1,987
    102
    209
    Quote Originally Posted by indianamoon View Post
    I should have said, this is going on a surface grinder.....I would rather use an overhead method, that's why the question on the magnet strength?
    Kevin
    Jan 2003
    1,987
    102
    209
    I picked this sine plate up yesterday, I used a 6" square plate with an eyebolt, the force of the magnet was enough for lifting!
    Thanks for the replies.....
    Kevin
    Nov 2014
    Florida
    4,511
    1730
    2163
    See you got it sorted. One thing we used to do when lifitng questionable size plates with a magnet was to lift it 1/2-1" high and give it a couple wacks with a deadblow, if it held it was good.
    One thing that might be captain obvious is never get any body parts under what you are lifting (even if you are *sure* it is solid)!!
  7. Likes AD Design liked this post
  8. #6
    Jan 2003
    1,987
    102
    209
    Yeah, that's what we did.....we also only raised it high enough to transport, then raised it to where it was needed!
    Kevin
  9. #7
    Jun 2012
    Tennessee USA
    917
    611
    535
    -Shock test w/dead-blow and minimal air gap is my last test before going further. I also use a magic marker to make pairs of alignment marks on mating components. The magnet may not let go but does it allow things to side? Just a suggestion.
  10. #8
    Jan 2003
    1,987
    102
    209
    Quote Originally Posted by AD Design View Post
    I will keep that in mind next time I need to move it, it didn't look like it shifted?
    Also, I'm going to call Suburban and try and get a manual/parts diagram and will ask about mag strength, maybe see what they recommend for moving the plate?
    Thanks again for the replies!
    Kevin
  11. #9
    Virginia
    31,228
    7561
    9806
    Quote Originally Posted by bsg View Post
    "For future reference.." Various plastic or bamboo, not take-away softwood Chopsticks. Bamboo skewers from the BBQ and kebab stash in the kitchen cupboard.
    Fair reliable at being non-magnetic, not easily split nor crushed. Handy sizes for enough height to get straps under it and secure them safely for a move.
    Sticks again at set-down location for clearing to get straps out and off.
    And then. Yer magnet lift - or pry lever - to get the sticks out is a very low gap so IF sumthin' DOES drop? It ain't ever by very much.
    I'm sure we all do similar stuff all the time with metal, plastic, scrap plywood, etc.
    I just happen to live in houses with more spare chopsticks and bamboo slivers than the average "Gweilo!" ....and find them HANDY, so stash a few in the shop tool-drawer.
    Kinda cheating to put greasy ones back in the Kitchen anyway!
