jeepinmatt
- Oct 25, 2009
- Charlotte, NC
I need a good solution for holding thin round shims on my rotary table grinder (preferably as thin as 0.002"/0.05mm, but a good solution will work for thick or thin). We currently have a Suburban fine pole permanent magnet, which i think has lost its strength, so I want to take this opportunity to get the "right" tool for the job. Shim diameter ranges from roughly 1" to 4", with the majority of the work in the 2-3" range. FWIW, grinder is a Delta LC400 (Delta LC400 rotary table grinder- Surface Grinding Machinery UK )
I've seen the radial pole magnets, but not I'm sure they would offer any more clamping force due to the hollow center of the shims. What says the wisdom of PM?
