I recently landed an old Brown & Sharpe Micromaster 510
and I finally was able to get it settled, wired, and tested yesterday.
After making a diamond dresser and dressing the wheel,
I noticed that it seemed to be wearing a groove pattern into the wheel
and that the grooves seemed to correspond to positions of the handle for the table lead screw.
Running an indicator on the table (from the column), the X-axis traverse is pretty dead nuts,
but the Y-axis seems to jump +/- 5 thou
leading me to believe that the Y-axis lead screw is bent or something like that.
When I was picking up/moving/landing the machine,
I failed to understand how the table worked,
so I definitely put a bunch of undue stress on the Y-axis.
Is there deeper troubleshooting I should do?
If it is a bent Y-axis lead screw, is it simply a matter of replacing it?
Or is there no "simply" about that sort of operation?
I'm a pretty new, relatively self-taught machinist,
so I'm good at figuring things out and fixing them,
I just don't have years of experience under my belt.
Thanks in advance for the help.
I've used this forum for answers for a long time,
but have never had so specific an issue as to warrant joining and making a thread.
Attached is an image of some test grinding I did after dressing the wheel.
The milled surface finish is visible on the left (and pretty flat)
vs the very obvious grooves generated by the surface grinder on the right.
