make a dust collector to fit a KO Lee 6x18 SG?
Results 1 to 18 of 18
    May 2006
    Seattle
    2,476
    61
    637
    Default make a dust collector to fit a KO Lee 6x18 SG?
    I ground some cast iron awhile back. The iron was beautiful but black dust was spread over a wide area in my shop. I've looked for a commercial solution but can not find one. I have a good little dust collector called a Dustkop Model 520. It has a 4" flex duct to connect to a machine. I know how to make square-to-round and round-to-round ducting connectors, so the duct port size isn't that critical. If I remove the front and back guards from the grinding wheel, the mounting ring is 3.75".
    Have you actually fabricated a dust collector fitting? Got a link? Description? Pics? Plans? Sketch?
    metalmagpie
    Mar 2002
    dallas,tx
    2,669
    739
    551
    There was a company called Electrodes Inc. that made a cast alum. vacuum wheel guard called Vac-U-Guard. No longer in business, and there are later versions that are plastic. Seems alot of these were sold over the years, I would keep an eye out for one. I think they were machine specific, but you could probably find one and make it fit.
    Jun 2012
    Michigan
    13,474
    4586
    4853
    The near-wheel catch doesn't work as well as a catch box down at table-end on the sparks go side.
    The catch box set in the coolant rail, with the dust collector attached to the end of the box...or tee it into the near wheel vent.
    Easy to fab a box up of cardboard and take to the fab to a sheet metal bender/furnace shop.
  4. Likes machinistrrt liked this post
    Sep 2005
    Northern California
    1,076
    173
    I agree a catch box off the end of the chuck works best. Having said that my home shop Taft Pierce came with a cast dust collector wheel guard with 2" port. I added an adjustable tongue so you have a scoop that can be set to ride just above the wheel / work interface. The trick is sufficient air flow, ie not a shop vac. Your dust-kop should be ideal.
    A similar pick-up could be fabricobbled pretty easily.
    IF you're set up to do that sort of work like Michiganbuck said...posterboard, hot glue, gorilla tape. When you've got something you like, take it to a HVAC shop and get them to make something a bit more robust that looks something like your model.
    Sep 2015
    Ohio
    1,772
    1170
    1894
    How about a heat register fitting?
  7. Likes ratbldr427, bryan_machine liked this post
  8. #6
    May 2006
    Seattle
    2,476
    61
    637
    Quote Originally Posted by michiganbuck View Post
    I've thought about what you wrote, michiganbuck. To fix a collector to the table which reciprocates closer and farther from the wheel which is the source of the dust, just seems wrong to me. Seems like it would have to work better when it's closer and vise versa.
    I realize you are the past master of the cryptic-guru sayings and that people like me are supposed to spend hours pondering what you mean by "the coolant rail" or "the near wheel vent". No matter how I masticate on it, these terms just don't mean anything to me.
    metalmagpie
  9. #7
    Aug 2004
    Centerville,OH
    2,181
    6
    99
    An old thread on the dust collector I made for my KO Lee: Grinder Dust Collector Project-Prototype
    Links to pics at the bottom of the first post. I've been using this system successfully since I posted the pics in 2005.
  10. #8
    May 2006
    Seattle
    2,476
    61
    637
    Quote Originally Posted by Holescreek View Post
    Yay! I'd been hoping for a reply like yours!
    I know how to build a sheet metal rectangular chute (as you call it). And I have a nice dust extractor unit I just finished wiring up today. Purrs like a kitten.
    Let me ask you about your chute. Is it fitted closely around the left end of your mag chuck, or is that just an artifact of the picture?
    I see that you removed the dust guard from the left end of the table and bolted a rod which extends towards the chuck. The chute seems to have a pinch bolt so you can move it in or out. Is there another rod on the back that I can't see?
    The part of the chute that fits over the rod looks like a short piece of tube, perhaps a piece of EMT. Right above it is another shorter piece of tube. Is this just a spacer, or is there something I don't understand?
    Thank you very much for posting, Holescreek!
    metalmagpie
  11. #9
    Aug 2004
    Centerville,OH
    2,181
    6
    99
    The rods are only attached to the end of the table. They hang free near the chuck and have held steady since installed. My grinder didn't have a target plate on the end of the table when I got it so I used the pre-existing holes for the rods. I used the rods to enable sliding the chute back and forth in case I ran into a situation where the chute would be in the way but I don't believe I've ever needed to move it except for cleaning. My chute is made from 20 ga sheet metal and the tubes are scraps of black pipe. The upper tube is just a spacer. The bottom of the chute sits lower than the chuck surface and is kept close to the mag chuck as I can get it. The yellow paint really helps seeing the wheel gap over the parts when I sight along the top of the part while cranking the wheel down.
  12. #10
    May 2006
    Seattle
    2,476
    61
    637
    I made a mockup today. The idea was to make its opening 8x8" and have it 4" deep, with a 5" square back. Here's the basic idea:
    Originally I planned to have the 4" duct attachment tube centered on the 5" square back, like this:
    Then I realized I could angle the duct upwards, like this:
    That would allow me to mount it without removing the existing spark guard which I need if I'm going to run coolant. The duct would simply go up and over the spark guard on the end of the table. I'd probably support the flex duct using a loop hanger threaded to a bit of strut screwed to the ceiling.
    Anyway, that's my current thinking.
    metalmagpie
  13. #11
    GERMANY
    3,602
    2380
    1427
    Kudoes on the cardboard mock-up. I often do cardboard or wood mock-ups of machine mods, and find it very helpful.
    Another solution: grind wet. Did KO/Lee make a coolant-enabled version of this grinder? If so, maybe you can find the missing bits (drain pan, pump, ...) and retrofit. That's an excellent way to control the dust from CI.
  14. #12
    Jun 2012
    Michigan
    13,474
    4586
    4853
    "coolant rail" is just the raised part if the table that retains the coolant so it goes to the drain hole.
    "the near wheel vent" is having a dust pick-up very close to the wheel..but must sparks miss it because the part travel would hit it if it was in place to catch all the sparks.
    Most all sparks travel toward the end of the table so that is where i like a catch box and air draw..
    I like to set a sheet metal flat shield behind the chuck, perhaps 3-4" higher than the chuck, and going left way to the catch box to keep sparks from going that way. yes may need to remove when getting the spindle close to the chuck
  15. #13
    Jan 2007
    Flushing/Flint, Michigan
    10,436
    603
    8473
    Make as wide as possible.
    Back side limited but front side can overlap the front.
    Top vented design could maybe longer as your shown will suck air high but not low.
    Air/vacuum flow funny. I like a cardboard mock up and smoke tests.
    Maybe lower extensions that are chuck height.
    Dry and I recommend a "spark arrestor" of some sort.
    A very lightly wadded section of door screen works well and easy/low cost to change out.
    People think metal does not ignite and burn. Grinding fines sure will with a Bic lighter and burn so very hot.
    This a demo I do when new people aboard. Most all are surprised. Not a real fire or flame more a charcoal grill glow.
    If that inside your duct after years of use very hard to stop.
    I have never seen a over the wheel type effective.
    Why the top angled and not 90?
    Bob
  16. #14
    May 2006
    Seattle
    2,476
    61
    637
    OK - so you just mean a dust collector fixture that sits down inside the table. Makes sense.
    "the near wheel vent" is having a dust pick-up very close to the wheel..but most sparks miss it because the part travel would hit it if it was in place to catch all the sparks. Most all sparks travel toward the end of the table so that is where I like a catch box and air draw..
    By definition a dust pickup mounted near the wheel has to be above the mag chuck and above the part so the part can traverse beneath it. So I agree that sparks that travel horizontally straight out will miss them especially if the vacuum is wimpy.
    That makes sense to me too, michiganbuck. I'll think about that some.
    Couple of other comments: my grinder does have the full on wet kit but I've never used it (yet). Part of that is because I worry that the coolant will make a big mess.
    I'll respond to carbidebob's post separately.
    metalmagpie
  17. #15
    May 2006
    Seattle
    2,476
    61
    637
    Make as wide as possible. Back side limited but front side can overlap the front.
    I'm learning a lot about many things on my journey to accomplish dust collection on my SG. One of them is it's not complicated to lay out a sheet metal dust box. I have a piece of 4" OD 16 gauge tube left over from a job I did once, and the flex tube to the dust collector fits snugly over that. So making new dust boxes isn't a big deal. I did the cardboard mockup and made a couple of changes and I'm going to go ahead and fabricate the dust box that way. If sparks drop at the base of the dust box instead of going up the dust collector hose I'll come back and revisit your advice.
    Dry and I recommend a "spark arrestor" of some sort. A very lightly wadded section of door screen works well and easy/low cost to change out.
    People think metal does not ignite and burn. Grinding fines sure will with a Bic lighter and burn so very hot. This a demo I do when new people aboard. Most all are surprised. Not a real fire or flame more a charcoal grill glow. If that inside your duct after years of use very hard to stop.
    I'm not so sure it's easy to buy steel door screen anymore. Most I've seen lately are plastic or aluminum. I will have a look at the hardware store. Anyway, because of your comment I will add some kind of spark-arrest capability so I thank you!
    I guess I was influenced by Holescreek's positive experience with his design:
    Mine will be wider than his and not as tall. Since I am not intending to remove the dust guard from the left end of my table (visible above behind my cardboard mockup) the vac hose can not go straight off the end as Holescreek's does. That's why I put the hose connection up on the angled part, so it can go up and over that left dust guard.
    I thought about doing a rectangular-to-round sheet metal transition box. I researched how to lay one out and did the layout. I learned a ton about layout doing that. It takes more than layout, though. I watched a couple of videos by guys making square-to-rounds on a sheet metal brake and I see the technique for forming the round parts. But that's too complicated, so it's back to a plain planar box.
    metalmagpie
  18. #16
    Jun 2006
    Near Seattle
    5,260
    3864
    1596
    Grant - there's a kind of metal screen used in front of electrostatic air cleaners that might serve to catch at least large sparks. Something you find in HVAC area rather than screen door area.
  19. #17
    May 2006
    Seattle
    2,476
    61
    637
    Quote Originally Posted by bryan_machine View Post
    Ah, yes, aluminum mesh filters. I can buy the ones intended for use on range hoods, and they would fit my dust box opening. This will require some thought.
  20. #18
    Aug 2004
    Centerville,OH
    2,181
    6
    99
    The metal dust from grinding will always drop downward as it looses speed after it leaves the grinding wheel. Having the vacuum connection at the top of the chute will allow the heavy grit and metal dust pile up at the bottom of the chute while only a small portion of the clean air and very fine particles will actually make it into the dust collector.
    The height on my chute was determined by the height of the bottom of the grinding wheel near the top of it's travel. Not all of my grinding is done at the magnetic chuck level, I have several accessories that sit on top of the chuck for spin grinding and such.
