RJT
Titanium
- Aug 24, 2006
- greensboro,northcarolina
If you had 400 pcs of .442 diameter parts 6" long made from .5 diameter PHT 4140, would you turn most of the material first, then get it centerless ground, or leave it in 12' lengths and centerless grind all the material off? It needs to be ground for surface finish and size tolerance. Not familiar enough with centerless grinding to know which is more cost effective?
