Lost in LA
Cast Iron
- Jan 31, 2005
- Los Angeles
Just purchased Mitsui 6x12 MSG-200MH (Mfg date 1994)hand operated surface grinder. It has ball table ways. It was shipped by truck with the balls removed. It seems to be in very good shape with the exception of the longitudinal ball ways on the table. This was expected.
Both the balls and ways are hardened and replaceable.
There are two sets of ball ways (front + back) that are retained by a linear phenolic cage. The balls are 5/8 diameter. The balls have a bit of scuffing and the ways have a witness line that is probably a few tenths deep. The ways also have scuffing both above and below the witness line. I have purchased a new set of balls (about $500 incl tax and license).
I have a couple of thoughts about the ways.
First the way scuffing is all along a fine line at the ball tangent point. Would it be a good idea to take a .6200 gage pin and carefully wrap an abrasive paper (brings it up to .625) of 1500?? grit around it to remove the high spots on the the witness line?
Then install the new balls and see what I have.
Or:
Should I consider purchasing a set of ground factory ways (4 pieces front and rear top and bottom). about $3000.
Or who regrinds Mitsui ways?
Sorry about the bad job of posting pictures!
Thank you,
Lost
