Are my spindle bearings fucked??
Page 1 of 3 123 LastLast
Results 1 to 20 of 42
    Jun 2002
    CANADA
    British Columbia
    3,259
    3228
    Default Are my spindle bearings fucked??
    Good afternoon All:
    So my new to me Jones and Shipman is proving to be a disappointment; I have lots of small problems to fix.
    I also have a really big problem to fix and I need the advice of other experienced eyes.
    I can't grind a decent surface for shit.
    Attached are two photos.
    This is with a balanced wheel freshly dressed taking 0.0001" DOC and 0.100 WOC.
    If you look at the surface of the mag chuck (ignore where the previous owner burned the shit out of it on the sinker EDM) you can see waves...the wheel is bouncing.
    The first photo is right after the grind, the second is after stoning the surface to bring out the contrast.
    If I take a bigger cut, say 0.0005" it's much better but still nothing to write home about and I get steps in the surface as if the wheel is dropping deeper on one side of the stroke than on the other.
    The steps are maybe 0.0001" deep but they're definitely there.
    I've tried everything I can think of:
    The hubs blue onto the spindle taper properly
    The wheel is tight on the hub and is dressed all over and balanced.
    The hub is tight on the spindle taper.
    I've got about 0.0003" of runout on the taper when I clock it, but it runs free and doesn't hump or grind.
    I put a glass of liquid on the wheelhead while it's running and can't detect any vibration.
    I think the spindle bearings are shot...what say ye all?
    Cheers
    Marcus
    Sep 2006
    Abingdon, VA
    3,796
    5020
    3809
    No idea about your bearings, but you get my vote for the most entertaining topic title!
  3. Likes ranchak liked this post
    Mar 2005
    Indiana
    6,438
    2279
    2406
    These run solid ways on oil, right? I would almost think something to do with table travel because of the way the lines are perfectly aligned. If it was a spindle bearing issue I would not expect to see those lines forming a straight linear pattern across the surface like that. Out of curiosity, what speed are you running the table at? Have you tried it at a pretty high speed? Does changing the table speed affect the spacing or linearity of the lines?
    Jun 2012
    Michigan
    14,242
    4854
    5136
    Give Ekrets credit for the first call..see that your long ways are wet with oil. then post the hardness of the wheel, it looks like a 46 something from here, but if too hard and it may be loading up. A loaded wheel likes to bounce. Making big crossfeeds can load up a hard wheel, or make a wheel bounce. Climb grinding can also make a wheel bounce.
    I would fresh dress and take a slow pass across a slug of mild steel with the long ways oil-wet. try that part at center chuck, then at the very end of the chuck/left.
    Qt [I think the spindle bearings are shot...what say ye all?].. could be(?)
    Might give the chuck a bang-bang with a whacker and see that the chuck is solid on the set pad, the wood handle but of a good size hammer would do, whacking straight down with using your other hand to feel. A slim possibility the burning of the chuck made the chuck warp and so a hollow under the chuck.
    A push-pull of your wheel head to see it is not too free...and a push-pull of your spindle.
    A spindle bump can more seat the bearings and so preload may need a little tightening..but check out everything before blaming the bearings,
    Oh, and be sure your diamond is turned to a fresh facet.
  6. Likes Jim Christie, stephen thomas liked this post
  7. #5
    Jun 2009
    Michigan, USA
    4,813
    3543
    2496
    I always had good luck grinding tables with a aluminum oxide wheel of about 46 grit as I recall. White wheel. Also use a very wide step over to avoid loading the wheel.
    Edit to add: Make sure that you have a sharp diamond on your dresser. Diamonds do wear out and get rounded instead of pointed and that can cause your wheel to bounce.
  8. #6
    Feb 2001
    Redwood City, CA USA
    5,348
    252
    1208
    Can you divide the ripple spacing by the traverse speed and see whether that equals the wheel rpm, with proper accounting for units? Thinking out loud, if the ripples are .25” apart and the traverse speed is 450 in/min (7.5 in/sec), then the ripples would happen every 33.3 ms, which would correspond to 1800 RPM if the ripples are due to once per rev of the wheel. Are those numbers anywhere near the ballpark?
  9. #7
    Jun 2009
    Michigan, USA
    4,813
    3543
    2496
    How fast are you traversing across the wheel when you dress it? Don't dally dressing it. Move along swiftly. The idea is to sharpen it, not glaze it over.
  10. Likes Jim Christie, stephen thomas liked this post
  11. #8
    Mar 2007
    L'Orignal, Ontario Canada
    2,425
    2654
    1084
    If you haven't used a surface grinder much or seen these videos ,they might be worth a look in case you find something that you are overlooking.
    How to Dress and Balance a Surface Grinder Wheel - YouTube
    How To Grind A Surface Grinder Chuck - YouTube
    SuburbanTool Inc - YouTube
    Links were posted to other videos on his channel on the Antique Machinery Forum a while back .
    Norton used to have more about the dressing tools on their site
    Optimize Grinding Processes with Proper Truing and Dressing Tools | Norton Abrasives
    If the bearings are not obviously loose or noisy , wheel dressing and table travel speed can affect the finish also.
    Cross feeding only when the table is traveling into or against the wheel and sparking out on the way back can sometimes help too rather than cross feeding both ways so no tendency to climb as in climb milling .
    Just a few things I might look at before writing off the bearings.
    Jim
  12. Likes michiganbuck, Paolo_MD liked this post
  13. #9
    Jun 2012
    Michigan
    14,242
    4854
    5136
    Oh, Don's YouTube reminded me that a line-up mark from the wheel to the mount will tell that your wheel did not move around on the mount. I think he forgot to mention that.
  14. Likes Jim Christie, Janderso liked this post
  15. #10
    Dec 2012
    AUSTRALIA
    4,836
    29
    1747
    Coarse grit,loose bond,sharp diamond,open dress......I much prefer to grind with coolant,most problems disappear as soon as the fluid cools and washes the grind clean.
  16. Likes M.B. Naegle, stephen thomas liked this post
  17. #11
    Dec 2012
    AUSTRALIA
    4,836
    29
    1747
    And dont go grinding your chuck unnecessarily....it will start to leak coolant and freeze up.
  18. #12
    Jan 2005
    The Netherlands
    6,828
    378
    2027
    If you stop the spindle it should come to a quick stop Ecspecialy the last bit If not the bearings are too loose Also make sure you use the right oil for the spindle Thin as water
    Peter
  19. #13
    Jul 2007
    UNITED KINGDOM
    5,513
    3471
    2853
    Were you using the hand feed instead of the hydraulic feed? They should be interlocked so the hand feed pinion can't be engaged at the same time as the hydraulic feed is engaged.
  20. #14
    Virginia
    21,048
    7561
    12308
    Quote Originally Posted by implmex View Post
    Good afternoon All:
    Cheers
    Marcus
    "Out of specification" possibly. Totally ruined, maybe.
    But "F**KED?"
    WTH did you DO?
    Give the grinder the keys to the car?
    You'd have to know teenagers and "raging hormones"?
    Seriously, how hard is it to read PM as to how OTHERS have checked their bearings for deflection and TIR?
  21. #15
    Apr 2013
    Damascus, MD
    1,711
    5033
    976
    Another way to check if the problem comes from the ways is to put a parallel on blocks over the chuck (or table) and indicate with a tenth indicator while moving the table: it doesn't matter if the parallel is not perfectly leveled. What you're looking for are small bumps in the movement of the needle.
    Paolo
  22. Likes Jim Christie, eKretz liked this post
  23. #16
    Mar 2005
    Indiana
    6,438
    2279
    2406
    Quote Originally Posted by Paolo_MD View Post
    Paolo
    I was just coming back this morning to read replies and say that same thing. I was also curious to know how high the "bumps" were. The picture makes them look huge, but pictures aren't always very telling.
  24. Likes Paolo_MD liked this post
  25. #17
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,494
    4384
    4104
    Pretty sure that surface has nothing, or at least not primarily, to do with bearings. It's too regular.
    46I fast, sharp wheel dress with sharp diamond facet.
    If that does not fix it, try setting auto at about .005" step with perhaps .003 down and let it run for a few inches width on a scrap work piece.
    If the head is bouncing, floating, the slow cross feed should smooth out.
    Rack could be exasperating the condition - say if table ways are worn enough that the gear/rack clearance has closed up a bit.
    smt
  26. #18
    Mar 2005
    Indiana
    6,438
    2279
    2406
    I agree that the lines are too regular to be a spindle bearing problem. There's no way the spindle would stay clocked to the table like that to make straight lines all the way across.
    I don't think this machine has a rack though. I believe it's like my Micromaster in that it uses a hydraulic cylinder to move the table back and forth.
  27. Likes stephen thomas, Dan from Oakland liked this post
  28. #19
    May 2009
    Canandaigua, NY, USA
    3,415
    178
    1733
    Well, all of the above. I'd never grind a chuck until I knew the grinder was working perfectly. And you don't want to grind out damage as that would mean grinding way too deep, just get the surface touched up. The bearings are likely fine, but when I got my ancient B-S, the grease was hard, contaminated and I don't think the preload Bellevilles were doing their job. Cleaning everything, especially the bearing bore, and reassembling resulted in a much better running spindle. Even though my bearings aren't perfect, having the right preload works wonders and the surface finish is fine. I did have some contact with the screws holding my rack, which was an easy fix. As for balance, you should hear only the hiss of air around the wheel, with no lower frequency hum. If you hear any lower tones, it's probably not as well balanced as you think. Run it with no wheel. I had to rebalance my motor before I was completely happy.
  29. Likes stephen thomas, michiganbuck liked this post
  30. #20
    Jun 2012
    Michigan
    14,242
    4854
    5136
    We need Bruce Ballen to chime in on this as he tore down a Shipman and likely could throw in some light.
    A fresh dress *(with a tuned diamond) and a full wheel grind with only down feeding(no Cross), to only down feed .0001 to .0002 per grind side-direction long traveling only, very slow across. No down feed on the climb-side but just Passover should prove the spindle bearings good or not so good...yes spray bottle coolant is good for this.
    Yes, on a piece of mild steel (CRS ok)
    slow long travel might be 1 1/2 feet per second...perhaps 3" long piece of steel (?).
