jhe.1973
- Mar 30, 2006
Hi Everyone,
I am working on a new (to me) toy & I am having a bit of trouble trying to get the spindle out of the quill. It has about .008 thousandths end play & that seems a bit much to me. I plan to take it apart for cleaning & to see how it is adjusted & compensated for temperature rise as the spindle runs.
I am used to seeing the bearing end play adjustment at one end & the other being allowed to expand. Does this one work that way?
Before I can get to that, I believe I need to remove the tapered insert that holds the grinding wheel adapter and that is where the problem is coming.
As you can see, the threaded stub for the adapter is broken and when I back out the center 5/16 socket head screw it only comes out this far. It turns freely but will not come out any farther. It feels as if it is being held by a snap ring, or shoulder of some kind, on the other side of this tapered adapter.
Is this tapered adapter supposed to be forced out by a couple of wedges as are used for drill chuck removal?
Any help would be appreciated and thanks in advance for your time.
Best wishes to you all.
Sincerely,
Jim
Sincerely,
Jim
