elysianfield
Cast Iron
- Feb 28, 2007
- Myrtle Point, Oregon USA
Hello!
Just received my Gallmeyer and Livingston vertical spindle rotary table grinder...7 1/2hp with an 8" wheel. It lists the spindle voltage as 240/480...and it is currently wired for the 480 volt application. I need to know where the change-over wiring is located...behind the 6 prong plug common to these beasts, or is it located at the mounting point to the vertical column on the machine? I would like a heads up before putting a wrench to the machine...anyone ever worked with one of these grinders? Any help appreciated.
