Norton universal od id grinder
Results 1 to 7 of 7
    Oct 2014
    29
    Default Norton universal od id grinder
    I have a Norton Universal 14" od Id grinder. I have been noticing the table travel is getting slower to just about non
    existent. Machine is about 40 or more years old still is very accurate. I bleed the hydraulic cylinder off on both sides pretty much the same. I have good hydraulic pressure and plenty of hydraulic fluid. Wondering where to look now?
    Any ideas??
    Aug 2014
    New Jersey
    113
    5
    39
    Way lubrication. Failed o-ring in hydraulic circuit. Varnish/dirt accumulation. Spool valve bypassing.
  3. Likes Matt_Maguire liked this post
    Oct 2011
    West-Central Illinois, USA
    1,275
    2022
    579
    Spool valves can wear, also the travel cylinder packings don't last forever. Less work to clean the hyd control spools first & see. I could be just slow/sticking in the reverse/tarry part of the circuit.
    My guess if it changes direction as expected (timing) and just slow travel then it is the piston packings. Usually you look at the ways & there should be plenty of oil weeping from underneath. With good pump pressure the course hand feed should feel like power steering, not like a lathe saddle - no matter the table size.
    Good luck
    Matt
    Oct 2014
    29
    That will get me started looking at some different places
    thanks for the help
    Jul 2005
    Cottage Grove, MN 55016
    7,642
    4116
    4561
    Un hook the Hyd. Cylinder and lift the table off and clean under there and check t be sure the table is getting lube. Many times the ways get jerky and slow when all the scraping wears so flat you get "stick slip". Good preventive maintenance is to pull the table and clean under there. What do you consider good Hyd. pressure?
    Rich
    Oct 2014
    29
    I believe the book says 200 psi
    Oct 2014
    29
    Ok had a repair service come in he took the front cover where all the controls were located and ended up adjusting the pressure for the tarry
    and that fixed it
