Odd Weldon grinding fixture ?
Results 1 to 5 of 5
    Jul 2004
    Northwest Ohio
    381
    15
    32
    Default Odd Weldon grinding fixture ?
    f289e083-5f24-45ed-a663-8ee0b54ec49e.jpgHad this on then shelf for a few years, haven’t paid much attention to it till now. Did a google search and didn’t find any pictures like it. The patent search only had a generic image of the Weldon style end mill fixture. The cams are ground with a decreasing radius to a sharp rise followed by a short flat. That are marked, see the pics. The spindle takes a 4c collet, there were a couple fractional sizes in the box. The tilt base was tagged as such, no other tags on the fixture. Any ideas ?a4b226f1-6072-4b9d-af59-30be49820bc1.jpg9618e669-c3c3-496b-b8b3-adfd6fdf5e37.jpg528a3929-1a5e-48f9-a1d2-75b0fafe9b9f.jpg86a74c70-c9c3-4864-8a6a-9bb1efd1b6c0.jpg
    Jul 2009
    NW Illlinois USA
    433
    103
    137
    Radial relieving setup perhaps. Sharpen taps.
  3. Likes sfriedberg liked this post
    Jul 2004
    Northwest Ohio
    381
    15
    32
    The single event nature of the cam didn’t seem compatible with a multi flute tool. I have a Hibco tap grinder that adapts for sharpening 2,3 and 4 flute taps. Single flute counter sinks ?
    Aug 2015
    Illinois
    1,487
    1087
    635
    As it is it appears to grind radial relief on single flute cutters (contersinks). There may have been other cams available for multi-flute cutters. That would make it much more versatile. I did notice the fixture was sitting on a sine-bar base. That eliminates the need to set the cutter below the wheel center (or above depending on what direction one is grinding).
    Jul 2004
    Northwest Ohio
    381
    15
    32
    Single flute grinding looks like the best choice given the cam profiles. I have a 9/16” 4c collet on the way. Then I can use the collets from my Black Diamond drill grinder to chuck up some counter sinks and see what happens...
