MichaelP
Titanium
- Dec 7, 2008
- IL/WI border
Just bought and received the unit. The Operating and Service manuals are available too.
I need to lift the machine off the pallet and put it on a mobile base. Guys from Oliver didn't exactly remember how this old grinder was designed to be lifted, but I received a couple of helpful suggestions from Mike here.
Now after I cleaned the machine outside, I think I can use those two 3/8-16 threaded holes used to attach the wheel guard on the top of the unit. A couple of eyebolts screwed all the way down might work, IMHO. The machine is just shy of 1,000 lb
What do you guys think?
Also, I'd like to get helpful hints on those who actually use(d) the grinder. Any suggestions of how to clean the chuck before the first use? Should I remove it for cleaning? The manual strongly warns against chuck disassembling, but doesn't describe how to clean it well.
Any advice of chucking drills securely (tapered or straight shank)? Drill positioning, most often used clearances, etc. Any tips and hints will be much appreciated. I read the relevant forum posts and did some searching on the Net, but want more. The manuals, although very helpful, are quite brief.
Did you cover the universal joints with boots of some kind (DIY or commercially made)?
Thank you.
Thank you.
