Parker 3x1209-6 spindle rotor removal
Likes Likes:  0
Results 1 to 2 of 2
    Jan 2009
    Melbourne
    10
    Default Parker 3x1209-6 spindle rotor removal
    I have a Parker #2 surface grinder, bearings are being replaced. Front bearings were easy. This spindle has the integral motor, the rotor is pressed and keyed. I am having zero success getting it off, I have tried a puller and the puller and some mild heat, it moved a 1/4 inch. Is there a trick to these or is this one just good and stuck? Im wary about putting in on a press, the rotor body is aluminum. Anyone battle this one?
    Jan 2009
    Melbourne
    10
    For anyone who might run into this issue. rotor appears to be loctited on, about 500 deg for 5 minutes got it to release.
