Parker Majestic #2 grinder
Results 1 to 9 of 9
    Jun 2008
    Mississippi
    252
    10
    Default Parker Majestic #2 grinder
    I am 100 percent new to any type of grinding but I just picked up a Parker Majestic #2 surface grinder and am trying to learn. From what I can tell it is in excellent shape but has been in storage since the late 70's or early 80,s from what I was told. I want to pull it apart and clean everything before I get started running it. I did have a chance to run it though and the spindle runs fine and the table moves very smooth.
    Does anyone have a manual they can send with what oils to use does it take oil for the spindle? I don't see any place to check or fill it with oil.
    Does anyone have a breakdown of the spindle? or info on it? I am wondering if there are any seals or adjustments.
    The only problem I am aware of on the machine is the electromagnetic chuck is not working. I checked and it doesn't seem to be getting voltage to che chuck. After I bought it and opened the cabinet we did find a a manual chuck.
    Do I really need a balancer? I got a few dozen new wheels and a few old ones but only 2 hubs. Are all hubs the same why are some left hand and some right hand I see on Ebay?
    I plan to start out by grinding the table then putting the chuck back on and grinding the chuck. IT has a little surface rust on the table and chuck. I have a MQL coolant mist nozzle I plan to put on the machine when I get it up and running. Any recommendations on what type of cutting fluid to run in it?
    Any recommendations would be helpful. I have been watching what I could find on Youtube (suburban tool) but there does not seem to be much info on grinding.
    Jun 2012
    Michigan
    11,349
    3884
    4007
    *Someone posted the Walker How to Grind a magnetic chuck instructions just a while back..it was pretty good and perhaps they will re post it or you might search for it.
    *Very easy to burn a chuck and pretty much ruin it,
    QT OP...[I am 100 percent new to any type of grinding ]Then you are very likely to burn the chuck so putting permanant stresses..
    If nobody posts a good plan I will come back tomorrow.
    Buck
    Jun 2008
    Mississippi
    252
    10
    I am worried about both grinding the table and the chuck but I am assuming they need to be done with both the machine sitting that long, moving and to get the surface rust off. If not please let me know.
    I picked out some 46 grit wheels to do this
    AZ46H12 V32A
    Does this look like a good wheel?
    I will be hooking it up to a vfd so. I am assuming controlling the surface speed may help keep the table and chuck cool.
    Jun 2012
    Michigan
    11,349
    3884
    4007
    Right and left mounts. Only use the one with the left-hand threat, sell the other so out of your shop.
    That wheel should be OK. I like white and pink if the pink id from radiac.
    Open wheel is the space between the grits. I don’t know how open that blue wheel is. with 100% concentration there is no space and so with no space the wheel run hotter,
    vfd ..be sure to not run wheels faster than the speed on the blotter, ring test all wheels at mounting, mark all wheels with a mount up arrow on the blotterr.
    Grinding a Magnetic chuck (Old grinder hands please make comment if I have missed something here, or if you find fault...Buck)
    So very often a new grinder hand will choose first off to grind the chuck. This is a bad plan because grinding a chuck is for the seasoned guy/gal and some grinding time /experience should come first. Best to practice grinding a large part so to realize how heat can build and cause a burn not often common to grinding small parts.
    To begin it is not a bad idea to check under a chuck, rust can build up with being unnoticed and the chuck may have been ground with some rust under it. Some suggest to grind the set pad but I only do that if the machine has been re scraped or if finding the pad not flat. A grinder having poor way straightness due to bed wear or ball or roller racks wore out may be made worse by grinding the pad. Do figure 8 hone the set pad, and check it to be flat.
    Still, rust can induce stressing a table so grinding the set pad can be a good/Ok idea. I most often evenly figure 8 hone the set pad with a big fine oil stone, and do the same to the bottom of the chuck. Scraping the chuck is also a viable possibility but I have never done that. Grinding the bottom of the chuck is often done and needed if the bottom is out of flat. The Norton 6” or 8" stone is Ok for this task. I small stone bevel all the set pad edges that are under the chuck and stone bevel edges of the chuck. With the chuck and the set pad absolutely clean I use heavy lubrication oil under the chuck. 30 weight lubrication oil is OK and way oil is also good, Yes, not automotive crankcase oil. With the chuck in position I set the clamp downs so they hit the innermost area of the chucks set hold downs so they angle a little down and touch near the inside of the notch. I tighten with a standard wrench with a one hands medium pull. Care taken to see the chuck sets where one can long travel and cross-travel a wheel to be able to grind the entire chuck and off the back and off the front so the correct wheel width must be chosen. Walker chucks suggest 20- or 30-foot pounds and that seems fine likely I tighten to about that (20 is plenty).
    The magnetic chuck may be the largest thing a grinder hand might grind a so very important concern and consideration is due. Very often a new grinder hand or a new to grinding person will think grinding the chuck true is the first thing needed. This is a task for the seasoned grinder hand or at least one who has studied the proper method. Using the wrong wheel and rushing the job can ruin a chuck. A grinding burn can put stresses in the chuck that may cause years of problems. The act of grinding may seem easy at first when only a small portion of the chuck is being ground. When more or all of the chuck is being ground heat may build faster than expected. The grinding may seem to be going well with not noticing that heat generated has made the center portion swell and so when the job is done and the chuck cooled the chuck center may actually be low even when no burn or problem is noticed.
    The wheel choice should be an open wheel with having lower concentration (open). The grit larger and the hardness letter to the medium or softer range. I like a 46 h to 46 k wheel and that is likely the finest (smallest) grit and hardest wheel one should use. Many like a 36-grit wheel so getting a lower surface finish but less chance of a burn. I prefer a white aluminum oxide wheel as they seem to run cooler on mild steel as most magnet chucks are made of. Wet grinding is best even if a hand spray bottle is the only coolant source. Frequent testing the chuck for the slightest heat. The chuck can swell even when no heat is felt. When the whole chuck is being ground greater over travel at each end (going off) can be employed to aid keeping it cool. To cross feed only on the grind side and a no-feed on the climb side can also aid cooling if needed.
    When grinding and after a full chuck pass over the chuck should be allowed to cool and then with watching sparks often one can see the spark pattern/volume to see the spark- out are even at both sides and front to back. Only sparks at the right and left side indicates the chuck heat swelled and so took more stock off the middle or back side, this suggests that the chuck will not be true to flat. Many say the magnet should be on and this is true for the last .001 /.002. Prior to the finishing the chuck will run cooler with the magnet off due to not trying to retain or catch material from the coolant. Still grinding the whole job with the magnet on is fine and that way you won’t forget to turn it on..
    Good to check your set pad to be flat with using a straight edge and run a hone over it.
    If you grind the set pad run an abrasive paper over all the edges the hone the edges and then hone the top. The chuck sides and all edges should be flat honed and all corners and edges hone beveled and bug free.
    Be sure to take off the back rail.
    * Again, wet grind even if you use a hand spray bottle.
    * Good to buy a large plate of steel ¾ x 6” x 12” and make this your practice grind. You can use it for a checking plate so a practice with a purpose.
    1. Set the chuck on the set pad in a position that will allow grinding the back rail and centered to the set pad. Best to place the chuck where you can get the wheel off the chuck at the far side and off on the close side to be clear off the chuck. it is common to indicate a chuck side to make it square to the machine. Strike pencil marks Criss cross on the chuck.
    2. Dress a name brand wheel of perhaps 46 H to K /or 36 h to k. Tighten wheel as tight you can with one hand on the wrench and one on the wheel / Then set the wrench end on a block and make a little tighter.
    3. Balancing may not be needed for 7” wheel but 8” and up I recommend balancing, balancing is a plus for the 7”.
    4. Bring the dressed and not running wheel to hand feel the chuck at close to you at the far right and note that down feed number. Then bring the wheel down at the far away chuck center to rub and note that number. Rub very easy or you will need to re dress the wheel.
    5. raise up and come back down to .005 above the highest number and travel the parked wheel across the chuck to see that it misses touching the entire chuck.
    6. fire up the spindle at let run for 5 minutes if a bearing spindle /20 minuet if a plane bearing spindle.
    7. crank or auto feed long travel for 5 minutes to warm up the bed.
    8. With long traveling across right and left down feed .0005 till you get first spark at the close to you edge.
    9. long travel and incremental cross ¼ to 1/3 the wheel width per pass with spraying coolant on the chuck.
    10. cross and long travel all the way to clear the chuck at the far side with cross feeds off the chuck.
    11. cross feed back to the chuck front and with .0002 down feed grind chuck again.
    12. continue until all pencil Xs are gone.
    Pull down .00005 and take a spark out, or two.
    After top grinding the chuck hone bevel and de burr edges so there are no sharp edges, replace the back rail with first cleaning the screw holes and selecting high grade screws that are as long as possible with not bottoming out. Tighten the center most screw first the outer ones, tighten with a light feel of one or two fingers at about 2" on the wrench. Dish the back of the wheel so only the edge will grind the back rail. Bring the parked wheel to just feel the back rail and to feel your scale setting on the chuck. cross away and cross back to be .005 away from the back rail. fire up and with long traveling carefully come to touch the back rail and tickle grind to clean up. An over lip back rail is best. That is one that is 1/16 higher than the chuck with a lip that protrudes toward the operator position. *Much care here because it is not uncommon for a new grinder hand to accidently down feed and put a divot in the chuck when grinding a back rail. Another bump rail is handy at the go side of the chuck (left edge).
    Yes, an experienced grinder hand might take greater down feeds depending on the wheel and machine but for the new to grinding guy don't recommend doing that.
  5. Likes small.planes, AD Design liked this post
    May 2006
    Seattle
    2,065
    48
    400
    How to tell if the chuck (or a part) is getting warm? Infrared thermometers are now dirt cheap and simple to use. Harbor Freight carries one. I have one and have used it for years in outdoor cooking.
    A lot of guys suggest you tighten the chuck clamp bolt only at one end. The other end should be little tighter than finger tight. The reason is when the chuck warms up, it not only expands up, it also expands lengthwise. If it's hard bolted at both ends, it will bow up in the middle. This leads to deeper cuts and more heat being put into the chuck. This is a positive feedback system and is to be avoided at all costs.
    I ground in a chuck once. I was told you HAVE to use flood coolant even if you have to rig a pond pump in a 5 gallon bucket.
    metalmagpie
    Jun 2012
    Tennessee USA
    859
    549
    500
    I've ground several chucks but only when there was a measurable problem, an excessive number of divots, or a new chuck. Grinding in a chuck could easily take hours to do, most of the time involved was about heat control. Flood coolant is good but I've had to do this without flood coolant several times. A spray bottle, wet rags, limiting DOC to a few .0001's, and time between passes if that's all you have. That's the thing, finding something else to do in between passes waiting for the chuck to stabilize. It's not something to rush through. My final pass before spark out was with a fresh dress on the open wheel.
  8. Likes michiganbuck liked this post
  9. #7
    Jun 2008
    Mississippi
    252
    10
    Thank everyone for the recommendations.
    Due to the condition of the table and the chuck. Amount of surface rust. It is going to need to be ground I believe. It was stored in a non climate controlled building for many years in South Louisiana.
    I can rig up a flood cooling system. I have a spare coolant pump I can use.
    One other question is about grinding wheel hubs. Are there differences? or are all ginding hubs the same? What is the difference in a right and left hand grinding hub?
  10. #8
    Jun 2012
    Tennessee USA
    859
    549
    500
    Quote Originally Posted by cgmaster View Post
    No they're not all the same "type", if that's what you're asking. Are they all the same quality? Likely not, you get what you pay for just like anything else. LH or RH differences? It will depend upon spindle rotation of your grinder. LH for CW rotation of spindle, RH for CCW rotation. Michigan Buck suggested getting rid of the ones you won't need, that's good advice. Some more information from the Sopko site:
    William Sopko & Sons Co., Inc - Standard Taper Flanged Wheel Adapters
  11. Likes michiganbuck liked this post
  12. #9
    Jun 2012
    Michigan
    11,349
    3884
    4007
    Good to line up all of your wheel mounts on the bench. Check them for Right or Left and set in different rows. For the parker you only use the lefts. Keeping the right-hand ones on your shop will cause an accident so they should be gotten rid of. Tool and cutter grinders have use of them so they are easy to sell or trade.
    Next try each left-hand mount on your spindle end and check for a perfect fit to the spindle nose angle. It is not a bad idea to put a sharpie line on the angle to see that they match. Also check to see that the spindle nose nut has enough room in the counter bore for about a full nut of threads. For example, a ½-13 nut would have about a half inch of threads so needing about 6 turns in the thread counterbore of the mount. Any mounts that only allow about 3 turns might be questioned as possibly a homemade mount so need repair or discard.
    Next pay attention to notice how the flange nut fits the thread and travels the full length of the thread with no hang-ups as it travels and that the face of the nut and face of the mount are smooth. Finally, when mounting a wheel see that the flange nut pushes/tightens evenly to the wheel face blotter. It is not uncommon for a way over used mount to have a distorted thread from closing on the same wheel width wheel for many years and so it may feel tight with not tightening on the wheel. Check also to see that the flange nut will be pushing to the proper surface or the back flange, so it is not pusunig to a recess of the back face.
    Any poor mounts should be discarded of spray painted so they have no chance of accidently being put on your grinder.
    With having a Tc grinder in your shop all the left-hand spindle end nut should be painter red so nobody accidently uses/tries a wrong nut.
    I like to mark all my mounts with a mark-up line and then mark a wheel being put on with a mark-up line on the blotter in a place where one can see when the wheel is on. Also I mark my spindle end with a mark-up line.
