Brian McKenzie
- Nov 10, 2007
- South Pacific
I have brought a 1983 model Proth (Taiwanese, similar to Chevalier) surface grinder back into operation after a break of 24 years.
I'm unsure of the purpose of the 2hp fan unit atop the left end of the coolant tank unit. There is a mesh basket (inside the side door) directly below the black return pipe from the grinder. A mesh screen, not in the path of coolant, is fitted between basket area and fan. Is the fan merely for cooling the coolant? I set it up so that it exhausts through the wall to avoid air blowing grit around the room.
I was going to fit a rubber seal in the gap where the fan outlet meets the PVC pipe, but in its current open state, it works like a venturi, drawing air in and expelling it outside. This might be helpful when grinding cast iron dry - to reduce iron dust floating in the air?
-Brian McKenzie
-Brian McKenzie
