evildrome
- Dec 31, 2015
- Paisley, Scotland
Hi All,
So I wanted to grind small points with better accuracy than the standard Quorn work holding equipment allows.
So, I made an air spindle from a standard ER11-16-100 collet chuck and a chunk of brass.
I made it to fit the Quorn work head clamp arrangement but I did have to drill and tap that for a 6mm air fitting.
That's it fitted.
But at that point (no pun intended) I really need to arrange things so that the spindle is falling down onto the wheel under its own weight.
And that meant some radical re-arrangement...
Using the air spindle to grind a point. - YouTube
I think I could get an ER20 collet holder fitted the same way so I may try that next.
Cheers,
Wilson.
That's it fitted.
Cheers,
Wilson.
