racking my brain
Results 1 to 7 of 7
    May 2021
    Delaware
    95
    24
    Default magnetic parallels for surface grinder
    Hey people,
    Midway thru another week. Back in the day, in the shop where I worked, we had a set of parallel bars used for holding parts on a magnetic chuck....easy you say, a dime a dozen....not so fast! These parallels were unique; one edge was serrated (not sharp though) and they were thinner in the center, along the length, and were manufactured slightly bowed...when you put them on the chuck, and it was energized, the parallels flattened out, providing some downwards pressure on your work...has anyone any knowledge of anything like this?
    Thanks in advance,
    Mark
    Feb 2019
    New York
    611
    613
    They are called "Perma grips" still sold by Magna Lock, they are not cheap though
  3. Likes Scottl liked this post
    Jun 2012
    Michigan
    14,391
    4902
    5204
    Better Title:
    "Hold down parallels for use on the magnetic chuck (?)
    Or the answer should be to "Go see a doctor".. *or your post locked before you get an answer.
    Nobody will search Brain Racking..A member since 2012 you should know better than such a poor title.
    Shame on you, bad, bad, bad....No desert for you, and go to bed now..... End of rant.
    *You can/should go back and change your title*. This is an important thread and should not be lost...
    ->Click on Go Advanced edit.
    Some grinder guys also called them chuck or hold-down combs.
    Workholding & Machine Tools | Rockford, IL | Magna-Lock USA
    Also, a good hold method is the have a bump stop in the go direction that is end angled upward so the part touching is touching at the part top edge, just below the grind size target.
    Buck
  5. Likes ballen liked this post
  6. #4
    May 2021
    Delaware
    95
    24
    Buck,
    Thank you for the constructive criticism point taken.
    Mark
  7. Likes 52 Ford liked this post
  8. #5
    Jun 2001
    downhill from Twain\'s study outside Elmira, NY
    11,534
    4413
    4136
    Yes.
    I've posted pix of using them a number of times, for bronze.
    Here's from a few days ago if you just scroll down:
    holding small flat brass parts for surface grinding
    Ralmikes Tool-a-Rama used to sell them, as did, IIRC, DoALL.
    I know they come up online though no longer cheap.
    smt
  9. #6
    Feb 2018
    122
    95
    35
    Robin Renzetti made a set on his youtube channel.
    Very hand to have
  10. #7
    Feb 2010
    ch
    3,478
    287
    484
    you can also use two thin, sharp blades that you press into the work and lock down on the chuck.
