I have some 3/16" diameter alumina rods that I need to grind a straight chisel tip on one end and also accurately grind to over-all length.
I don't have much experience using a surface grinder, let alone grinding ceramic. From what I've read, I should use a diamond wheel with ample water-based coolant.
Does anyone here have experience grinding alumina? What diamond wheel(s) would you recommend?
