Removing 4mm thick brake plates from magnetic chuck of a ring grinder
Results 1 to 6 of 6
    Aug 2010
    AUSTRALIA
    82
    Default Removing 4mm thick brake plates from magnetic chuck of a ring grinder
    Hi
    I have a ring grinder and after grinding the 4 mm thick plates I cannot get the electro magnetic chuck to release the part.
    The thinner plates vary in size from around 400mm x ID 200mm up to 650mm x ID 550.
    Even if I turn the machine off and leave them overnight they still not come off.
    I have no problem with removing larger heavier parts, just reverse the polarity for a couple seconds while hanging onto the part and off it comes.
    Any advice greatly appreciated
    Best Regards
    Burgs
    May 2008
    San Diego
    344
    65
    Lay a piece of clean, dry, unused paper between your ring and the magnetic chuck. Copy or tablet paper will do fine. The ring will be parallel within a couple of tenths if the paper is not wrinkled.
    Gene
  3. Likes cash, michiganbuck liked this post
    Aug 2007
    Wisconsin
    2,054
    1059
    902
    use your air gun and blow at the edge of the part. This may help to release it.
    I assume normally your magnet releases parts just fine? but these are coming very flay and "wringing" to the chuck?
  5. Likes michiganbuck liked this post
  6. #4
    Jun 2012
    Michigan
    9,476
    3234
    3396
    I have set-on plates and parallels with serrations so I can grind them for a very fussy job so not needing to grind the chuck. Perhaps such plates could be made so one might put a wedge under the part / or that they could not ring the chuck. Agree one does loose some hold doing this.
    The serrations allow grinding with less worry about stress and heat when a tickle grind is made to them, perhaps .0005 to .003 take.
    Yes I made them for working at the big shop where I might have to set work on a questionable grinder chuck.
  7. #5
    Aug 2010
    AUSTRALIA
    82
    Hi
    Thanks for the reply's, paper workedI used my wife's cooking paper 0.06mm Thick, tried A3 paper but coolant destroyed it.
    Just need to place a bit of 4 X 2 wood, on the inside of the plate, pull hard against it, reverse the polarity, and turn it off and I can slide the plate from there, only need a about 50mm movement then I can pick the plate up with an indicator magnet.
    Good thing is the paper also stops the plates from scratching.
    Normally I grind bigger heavier cast iron housings and pistons, these release fairly easily, just need to have a hand on and pull them when reversing the polarity, and off they come.
    Now I have a bigger problem, couldn't get a decent finish, and noticed the spindle was a bit noisy so stripped down and checked the spindle bearings, one of the four felt rough, so have stripped down ready for new spindle bearings, looks like $450 au each, ouch.
    Best Regards
    Burgs
  8. #6
    Apr 2006
    Manchester, England
    7,843
    1086
    4838
    What make of ring grinder do you have ?
    Regards Tyrone.
