Removing/Installing table drive cable on Mitsui 200MH
Likes Likes:  0
Results 1 to 6 of 6
    Dec 2018
    Tennessee
    16
    Default Removing/Installing table drive cable on Mitsui 200MH
    Title says it all. Will be taking this grinder for a 9 hour drive.
    Thanks Richard
    Jan 2013
    Plainfield, Indiana, USA
    1,678
    1263
    904
    When I moved mine I stretched a bungee cord under the grinder and fastened the ends to the cable. Did not leave any slack at all in the cable.
    Dec 2018
    Tennessee
    16
    Thanks Red I’ll give that a try.
    Regards, Richard
    Jun 2012
    Tennessee USA
    617
    272
    354
    It's been quite a while since I had to and my memory isn't clear but IIRC it's just a simple hook at one end that's threaded into the casting. Back the jam nuts off, pull the hook out and dis-attach the cable loop. The cable should come off the drum then. It's a 4-6 handed job but the table can then be lifted off. Good luck with the move.
    Dec 2018
    Tennessee
    16
    Thanks AD, appreciate the advice!
    Regards Richard
    Oct 2010
    Oregon
    4,873
    3872
    1751
    Detaching is easy. Reattaching can be fussy because you need to keep the cable wraps around the drum tidy (not laying over one another). That's easiest to manage by putting a small weight or other source of tension on the ends of the cable. The actual fastening of the cable ends to the table ends is trivial.
