Hi All,
This is my first post on this Forum. I am NOT a machinist; just a DIYer and tinkerer, so please be gentle if my questions are too basic or dumb
Anyways, I have just acquired an old, 6" bench grinder which I picked up at a yard sale. Having never used one, I tried to educate myself and have read articles and seen Youtube videos on the subject of bench grinders. It was certainly eye opening!
I would never have thought that a bench grinder could be dangerous (risk of grinding wheels exploding). The bench grinder as obtained was very dusty and filthy, so I decided to dismantle it and clean it. I took the grinding wheels off and performed the ring test and both wheels passed the test. Since they were very dusty and filthy, I decided to wash them. I just used soap and water and the wheels looked MUCH better after I was done. I dried the wheels with some rags and started putting the machine back together. Just before mounting the grinding wheels, I decided to do the ring test again and to my surprise, both wheels failed the test. I think it is because the wheels are water-logged. I did not mount the wheels and currently have them sitting vertically on a piece of cloth to drain the water. I have a couple of questions:
1. Is it safe to use a hair-dryer to dry out the wheels? (does heat expansion risk causing cracks?)
2. Is there any danger of the wheels exploding if mounted in their current (wet) state?
Thanks!
Thanks!
