Seeking Chevalier FSG-618M Information
Likes Likes:  0
Results 1 to 3 of 3
    Mar 2002
    Oregon
    259
    34
    Default Seeking Chevalier FSG-618M Information
    I'm planning to look at a Chevalier FSG-168M surface grinder next week. I've been searching the Internet trying to find a manual for it - so far, no luck. The most immediately needed information is that about lifting and moving. I did contact the U.S. office and, after asking for the serial number, they indicated that they did not have a manual available.
    From the photos that I've seen, there are two holes on the front that are probably for rigging together with corresponding holes on the back. If anyone has any information about moving these machines I'd appreciate hearing it. In particular, are the holes intended for a bar to be inserted through front to back or are they threaded for a bolt? Also, should the table be removed or is it acceptable to be strapped in place?
    Mar 2009
    Brunswick Oh USA
    4,543
    5089
    2711
    Lee's Machinery used to sell them,(I think). I've dealt with them in the past on my Chevalier mill and had good luck. Maybe you'll get lucky.
    Lee's Machinery - Industrial Company - Perry, Ohio | Facebook - 3 Reviews - 660 Photos
    Jun 2012
    Michigan
    10,211
    3462
    3647
    Many/most say to pull the table on ball way machines.
    I like to wrap a grinder to keep road dust out of the works.
    Setting the wheel,on a block of wood protects the up/down device.
    Re;
    Table traverses on hardened & ground guideways w/ steel ball bearings
    Turcite-B laminated and hand-scraped machine slideways
