Sharpening rotary broaches - Page 2
Page 2 of 2 FirstFirst 12
Results 21 to 22 of 22
  1. #21
    Nov 2018
    CANADA
    British Columbia
    153
    27
    104
    Quote Originally Posted by MichaelP View Post
    Now after you published your number, don't go far from your phone, Marcus.
    No,I shall call you in vain....
    Thank you! Most generous. I will be away for a few weeks (and possibly absent on the forum), but shall contact you when back. And following the above advise, will email the phone number rather than publish it
  2. #22
    Feb 2007
    Myrtle Point, Oregon USA
    337
    55
    249
    How to sharpen.... Using a Cincinnati Monoset, hold the broach tool in the tool head, rotate the tool head assembly to 45 Degrees. Use the smallest wheel you have available to you. Align the wheel head and the work head to the same plane/elevation...make sure the wheel is dressed and center one corner edge of the wheel to the center of the tool...kiss it while slowly spinning the work head. For small work (1/8 inch) I use a 1" diameter wheel.
  3. Likes matra liked this post
