Step Grinding?
Results 1 to 2 of 2
Thread: Step Grinding?
    May 2008
    Ohio
    177
    55
    15
    Default Step Grinding?
    I heard the term "step grinding" the other day in relation to extreme accuracy. Can anyone explain the process to me? Thanks
    Dec 2005
    Jersey Shore
    3,843
    279
    459
    My definition is dressing a wheel with a step of say .005 between them. I have done this with my old underpowered 5 x 10. So instead of a single .010 cut, you cut 2 x .005 at the same time. It seems to put less heat into the work, and needed less power.
    On occasions I used with the cylindrical grinder as well when needing to remove alot of stock in a short time.
    I have tried it for a final cut, like a .002 and .0005. it was not as good as a full face .0005" would be. But as you know YMMV.
