Sunnen bushing grinder
Results 1 to 11 of 11
    Jan 2019
    CANADA
    British Columbia
    16
    Default Sunnen bushing grinder
    I have recently aquired a Sunnen bushing grinder, obviously an older unit. The ID tag on the front of the machine says it is a model AHM. Serial number C7081
    I cannot find any mention of this particular model anywhere,...when I contacted Sunnen they said that any of the accessories in their catalouge will fit ??!
    This particular model has a piston type oil pump mechanicaly operated by a accentric at the rear of the mandrel shaft.
    Has anyone come across this model?
    Dave
    Attached Thumbnails Attached Thumbnails sunnen-bushing-grinder-1.jpg   sunnen-bushing-grinder-2.jpg
    May 2007
    241
    11
    27
    Could you please post a picture of the machine. There were a couple old machines that the current Sunnen tooling will not fit.
    Sunnen never used a piston type oil pump.
    Jan 2011
    BFE Nevada/San Marcos Tx
    1,317
    1276
    718
    Looking at the pic it looks like your machine would accept standard mandrels. Odd the label says "bushing grinder", mine says "precision hone". Sunnen for some odd reason had an automotive line (red), and an industrial line (grey), same machines, with different model numbers, maybe there were differences I am not aware of. The gauge mounted on upper right (whole unit, not just the dial indicator) is worth more than the machine, if it works.
    Aug 2005
    Toronto
    4,941
    3360
    3833
    its a hone not grinder.
    I've got what looks like the same one, except the oil pump on mine is rotary and underneath in the tank...powered by a round urethane belt. I'd always thought of mine as being an "LB" model but couldn't swear to it. Apparently all Sunnen tooling fits it, with the small sizes using an adapter ring. The tank and stand are custom made, the only room for it my shop was to make something that fit overtop of the phase converter
    Jan 2019
    CANADA
    British Columbia
    16
    Yes a bit of a mystery,... mine does accept the Sunnen hones. The lube pump is a piston type. The Other discrepancy is the drive belt, the OEM flat belt for a model L-BM for example is too short, also mine has a four stage pulley motor shaft and mandrel shaft.
    Jan 2011
    1,317
    1276
    718
    Friend in Tx has what for all the world looks like a Sunnen hone, but it has some other name on it, and label says "bearing grinder" iirc. My best guess for it, and maybe yours, is a special order, maybe from military?
    May 2007
    241
    11
    27
    You have an old bench hone that was made at Sunnens facility in Canada. Yes it will take the current tooling. The oil system must be home made or only used in Canada. Sunnen machines made in the US used centrifugal pumps. Sunnen no longer has a Canadian facility. That machine sold for $185.00 new with tooling back in the day
    May 2007
    241
    11
    27
    Being four speed step pulley means it was yes for industrial applications
    Nov 2014
    Florida
    4,131
    1620
    1941
    Funny this thread popped up for me today, found this on local craigslist
    Sunnen Hone Truing Sleeves -- Lot of 5 - tools - by owner - sale
    No idea if it is relevant or not, but price seems right maybe?
    Dec 2012
    AUSTRALIA
    2,622
    10
    820
    You have to be careful with Sunnen stuff....some users are in the habit of putting worn out tooling on sale ...never buy without looking and checking.....the cost of new tooling sucks newbies in.
  11. Likes gappmast liked this post
  12. #11
    May 2007
    241
    11
    27
    Quote Originally Posted by john.k View Post
    You may buy a truing sleeve marked 1125 but find it to be 1250 when measured.
