caliper
- Nov 30, 2007
- Martha's Vineyard, MA
I'm running my 1953 Reid 6 X 18 grinder with a 5hp Phase-A-Matic converter I bought used. It was made around 1991. I'm having trouble getting a good surface finish and want to eliminate everything I can before I consider spending $2K for a rebuilt spindle. One possibility is a problem with the phase converter. Is there a simple (with a voltmeter) way to check the output to the motor to see that the phases are balanced? Chuck is flat & spindle runout is under 2 tenths. I'm also about to install a VFD just in front of the motor to get the sfm down to a reasonable speed. I'd appreciate and and all advice.
Bill McConnell
Bill McConnell
