Surface Grinder table speed
Results 1 to 5 of 5
    Nov 2016
    FINLAND
    213
    12
    10
    Default Surface Grinder table speed
    I have a Chevalier fsg-1224ad surface grinder with hydraulic table feed and automatic cross and downfeed.
    I have been grinding only some steel for now and it seems that when i take the last few 0.0004" passes and run it with high table speed, i get better surface finish.
    Im new to grinding and im asking for your help!
    How to determine the right table feed speed?
    Sep 2017
    South Carolina
    416
    320
    354
    By sight and sound. You will know quickly if you have it wrong!
  3. Likes cash, michiganbuck liked this post
    Mar 2019
    UNITED KINGDOM
    123
    21
    It all depends on the type of steel (or any material) and it’s heat treated condition, whether it’s possibly annealed for fully hardened will have a massive impact on how it grinds. Also your type of wheel you are using, the wheels surface condition and also the size of wheel will have a impact of surface speed of grinding.
    Your table feed will have a smaller effect on surface finish compared to many other factors described above.
    Factors such as spindle condition, use of coolant and depth of cuts will have a greater effect.
    The table fees is more of a feel rather then a definitive calculation,
    ** it may be more of numerical factor in more specialised modern grinding machines but nothing I’ve ever come across**
  5. Likes cash, michiganbuck liked this post
  6. #4
    Aug 2007
    Wisconsin
    2,055
    1061
    903
    Suburban tool has many good videos on grinding that should help you out.
    YouTube
  7. Likes michiganbuck liked this post
  8. #5
    Jun 2012
    Michigan
    9,789
    3312
    3515
    The sparks can sometimes tell when running dry..when they seem to become a solid bar you may be going too fast. Running wet a noticeable slowing of spindle RPM is a dead give away.
    A change in sparks pattern, getting close together or changing color indicates part getting hot and may soon suck up into the wheel and burn so a slow down or better yet a pause off part.
    Parts sliding to the left direction a good hint. Parts flying off the chuck too fast and too late.
    So sound and sparks are the basic premise of too much travel speed.
    Re:Parts flying off the chuck can often be avoided with a bump-stop high on the go-side of the taller part, a block of steel, an angle plate, a double clamped finger from a steel block.. If you can tip over a high part with a two finger push it may a tip-over and go flying set-up. If a bump-stop is not square it may not be touching the part high-up so not very good... so the bump-stop can be turned 180* so it might bump high, or a shim can be place high on the go side
