#5 ii Alive!
- May 12, 2018
Hello. I don't think what I need exists, but you guys know a lot more than me.
I'm in need of a self-adhesive sanding paper that is also waterproof. Does such a thing exist? Hook and loop won't work because it has too much give.
Here's an example from Amazon of something that would be perfect, if it was waterproof.
Sackorange 60 PCS 6-Inch NO-Hole PSA Aluminum Oxide Sanding Disc, Self Stick(10 Each of 80 100 120 180 240 400): Amazon.com: Industrial & Scientific
Below is what I'm using now. It works perfectly, except when it wears out I have to buy a whole new disc, which costs at least $10.00. The material I'm sanding MUST be done with water, cannot be sanded dry. uxcell 6 inches Stone Granite Diamond Grinding Wheel Disc 400 Grit 1/2 inches Arbor Hole: Power Grinder Accessories: Amazon.com: Industrial & Scientific
Thanks in advance for your suggestions.
#5
#5
