QT:[I can then advance 20 tho and it will not even spark. ] that kind of nails it to the down feed. The weight of the wheel head should drop the head to what you hand wheel feed down. With everything in that works turning free..and fixed to each other so nothing is slipping....grit and grub may be in the works. Could be the column is not free for down travel. Cleaning or lube may be a factor. Might set an indicator under the wheel head and travel it a number of times to see it repeats the same each try.
*An almost shot down feed nut can do some odd things, and may even slip a half thread and lock solid, This can make tear down difficult..test the free travel at about 6" above the chuck. Don't crank hard because you might slip it doing that.. with over a half turn free play you better consider replacing that nut.
Next:
Guess you might hand push/pull about the column under indicator for starter.
See if the spindle is moving about in the way it is held in the machine.
Check to see there is no end play in the parked spindle.
Check the down travel nut, set a wood block on the chuck and drop the wheel on it ,then travel down feed to see how much free travel there is...and know that nut and the down lead screw is fixed tight.
Set an indicator some place on your saddle and see if a push pull makes any suspect movements.
Push pull on the cross and see if anything funny there.
Could be the way the machine sets on the floor, taking a clunk,clunk as the table weigh changes balance right and left..
Soft hammer bump the chuck in different directions to see no movement.
Yes this is just for starters
