Truing a Deburring Wheel
Results 1 to 7 of 7
    Aug 2006
    335
    75
    Default Truing a Deburring Wheel
    I've got a Norton Bear-Tex series 1000 convolute deburring wheel. The product number is 66261055205. The arbor hole just isn't concentric with the wheel. It's got quite a bit of runout although measuring it is difficult because of the wheel surface. I'm running it on a 6" Baldor grinder. This wheel makes the grinder vibrate something horrible. I can put a regular grinding wheel on and it runs fine. If this were a grinding wheel I'd just dress it and be done with it.
    I used an indicator with a think piece of shim stock to measure the TIR and it's about .013".
    Is there some way to dress these types of wheels?
    Apr 2019
    Arkansas
    359
    50
    160
    Quote Originally Posted by TravisR100 View Post
    just get a piece of steel that has a burr on it and press into the wheel while at speed. it will work itself out.
  3. Likes cash liked this post
    Aug 2006
    335
    75
    Already tried using an old file. May just need to go at it longer.
    Mar 2009
    Brunswick Oh USA
    4,514
    5011
    2687
    The wheels with a 5/8" hole work fine, but the 1¼" bores always fit loose on those cheesy bushings. I make them from Al. or plastic. Keeps 'em true.
    And wear a respirator!
    Aug 2006
    335
    75
    The wheel has a 1" bore and the grinder has a 1/2" shaft. I made a bushing so that it doesn't have any slop. It's just the outside of the wheel not being concentric with the bore.
    Nov 2004
    SLC, UT
    685
    881
    131
    Believe it is standard practice to dress these wheels when new and throughout their service life.
    4"x24" hard backed sanding belts, 26-36grit aluminum oxide work well for this.
    Put a backer behind the belt (like a 1" dowel or round bar) so you hold form on the face of the wheel.
    Don't dwell on a particular spot on the belt- dress a little, then use a different section of the belt or you will just burn up the belt and rub off the abrasive.
    Jan 2007
    Flushing/Flint, Michigan
    7,698
    384
    6417
    Lathe toolholder with carbide insert or just use the heck out it on a piece of steel.
    Hand held air beltsanders like a dyna-file with a coarse belt also work.
    Bob
  9. Likes Booze Daily, ballen liked this post
