weird grinding spindle
dian
Titanium
Feb 22, 2010
ch
im getting this small grinder operational and i wonder about the spindle. er16, around 15'000 rpm. its quiet, has no vibrations and is pretty stiff for its size, 0.01 mm up and down by hand pressure (0.0004"). however there is axial play of 1 mm (0.04"). when under power it gets pushed forward and doesnt seem to be rubbing, no idea if the belt/pulley does it or what. thre is no problem gringing with small stones (13 mm).
so i have been thinking, maybe thats how its supposed to be? kind of insurance against breaking the stone in a hole? i cant think of a configuration that would still run well with that much wear. could it be designed that way?
thoughts?
That's not right. This looks like a Fischer or SFJ spindle. Are you sure that there are no (faded) markings on the body?
A lot of spindle like this have a set of springs inside that preload the bearings. The bearings are intended to slide inside the body so that with thermal expansion they can move. If your spindle is designed that way, then the bearings are sticking in the body. So I would carefully open up the spindle and clean/lubricate it, checking that the bearings can move freely.
It sounds like the spindle was disassembled, and the spring washer not installed, or installed incorrectly. For sure not a normal thing to have, given the application.
so you figure this is an angular bearing spindle? there is no force needed to slide it back and forth. i cant measure any runout (<5µ). i was thinking mybe plain bearings with a thrust bearing missing? as i say, i runns well and sound good.
